[petsc-dev] Intel compilers + CUDA
Fri Feb 24 11:12:29 CST 2012
On Fri, Feb 24, 2012 at 11:06 AM, John Fettig <john.fettig at gmail.com> wrote:
> On Fri, Feb 24, 2012 at 11:56 AM, Satish Balay <balay at mcs.anl.gov> wrote:
>> for one I mistyped the option - it should be: --with-cudac='nvcc -ccbin
>> icc'
>> But then - should it not be c++? [as cuda internally uses g++ - not gcc].
>> So
>> --with-cudac='nvcc -ccbin icpc'.
>> But this gives me all kinds of wierd errors in configure.log.. Maybe
>> it won't work [with intel compilers]..
> CUDA .cu files are written in C with some extensions (that are handled by
> nvcc and not the passed compiler), so I think you have to use a C
> compiler.  You can't write C++ in a .cu file.
I do not think this is correct. You can have C++.
   Matt
> John
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120224/43257b47/attachment.html>
