[petsc-dev] Problem with MUMPS+metis
agrayver@gfz-potsdam.de agrayver at gfz-potsdam.de
Mon Feb 20 14:08:33 CST 2012
Yes, I use this one.
I do specify serial partitioning. Basically all parameters are the same, but mumps from petsc just hangs.
I work with ldlt factorization.
----- Reply message -----
To: "For users of the development version of PETSc" <petsc-dev at mcs.anl.gov>
Subject: [petsc-dev] Problem with MUMPS+metis
Date: Mon, Feb 20, 2012 20:42
Which version are you using?
The only version of metis supported officially by mumps is metis 4.0.3 which contains METIS_WND and was removed in favor of more arguments to METIS_ND. See my patch submitted here:
https://listes.ens-lyon.fr/sympa/arc/mumps-users/2011-11/msg00027.html
Search on their mailing list indicates others were successful in linking serially. Did you specify the option for mumps to use serial partitioning (through petsc options), out of curiosity?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120220/0b7f41e9/attachment.html>
