[petsc-dev] Problem with MUMPS+metis
Sean Farley sean at mcs.anl.gov
Mon Feb 20 14:10:07 CST 2012
> Yes, I use this one.
> I do specify serial partitioning. Basically all parameters are the same,
> but mumps from petsc just hangs.
It would really help me out if you could get a petsc example to hang as
well and tell me what options you ran with so I could try to debug locally.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120220/3c75dfc4/attachment.html>
