[petsc-dev] Problem with MUMPS+metis
Sean Farley sean at mcs.anl.gov
Mon Feb 20 13:42:18 CST 2012
> Which version are you using?
The only version of metis supported officially by mumps is metis 4.0.3
which contains METIS_WND and was removed in favor of more arguments to
METIS_ND. See my patch submitted here:
https://listes.ens-lyon.fr/sympa/arc/mumps-users/2011-11/msg00027.html
Search on their mailing list indicates others were successful in linking
serially. Did you specify the option for mumps to use serial partitioning
(through petsc options), out of curiosity?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120220/d12bc7e6/attachment.html>
