[petsc-dev] please make myself and Satish admin on bitbucket.org/petsc
Fri Feb 10 19:30:50 CST 2012
On Fri, 10 Feb 2012, Satish Balay wrote:
> On Fri, 10 Feb 2012, Sean Farley wrote:
> > > The point is that that permission is on a repository by repository bases,
> > > so every time Sean (who is the only one who can do it) adds a repository he
> > > has to remember to set the permissions for all of us.
> > Not true. You can log in and create a repository now. This is the same as
> > how petsc.cs.iit.edu works except that you can log in using an SSH key
> > under the 'petsc' username. So, store the password in your keychain ==
> > asking Satish to add your ssh key to /home/petsc/.ssh/authorized_keys.
> Barry is refering to repository creation - and you are refering to
> project creation. Not the same..
> With petsc.cs.iit.edu - yes I have to create a project manually and
> assemble the group and admin/s . But with bitbucket - you can create
> your own account [ala project] and assemble your own group - aswell as
> set admins.
minor modification:
with petsc.cs.iit.edu I create the project - and set the initial
admin/s.  They can login and set the group as needed.
But usually I'm also the admin as most folks didn't want to deal with
the admin part - it was easier to just tell me what was needed.  [its
usually manually editing authorized keys file]
I'll concede that the gui admin for bitbucket is perhaps
better. [instead of logging in shell - you log-into a website and use
the gui].
One good aspect of bitbucket thats not on petsc.cs.iit.edu is: If a
user exists in multiple projects - the keys are duplicated manually
for each project account on petsc.cs.iit.edu. However bitbucket
maintains a single copy and uses it across all projects.
Since the number of projects was relatively small - the lack of this
functionality wasn't a big deal..
Satish
> After this creation - on petsc.cs.iit.edu any user in the group can
> create repos without my intervention.
> hg clone foobar ssh://petsc@petsc.cs.iit.edu//hg/petsc/foobar
> With bitbucket - only owner can create the new repo [not any member of
> a default group]. Don't know about admins..
> wrt delete - petsc.cs.iit.edu admin for project petsc can ssh over and
> delete repos [via shell access]. Looks like with bitbucket - only owner
> can do the deletion of repo [not even admins]
> Satish
> > The only issue I see currently is the vanity of having the tutorials and
> > externalpackages repos listed. As I mentioned before, petsc.cs shouldn't be
> > hosted that long list of stale repos. A solution that would work now is to
> > use schemes and local folders. None of the bitbucket quirks would effect
> > workflow, only how the webpage looks.
