[petsc-dev] please make myself and Satish admin on bitbucket.org/petsc
Sean Farley sean at mcs.anl.gov
Fri Feb 10 19:23:08 CST 2012
> Barry is refering to repository creation - and you are refering to
> project creation. Not the same..
Righto, I see now.
> With bitbucket - only owner can create the new repo [not any member of
> a default group]. Don't know about admins..
> wrt delete - petsc.cs.iit.edu admin for project petsc can ssh over and
> delete repos [via shell access]. Looks like with bitbucket - only owner
> can do the deletion of repo [not even admins]
This is true. Barry already has the shared password for the petsc account
on bitbucket.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120210/3090ff10/attachment.html>
