[petsc-dev] petsc-dev on bitbucket
Fri Feb 10 09:52:36 CST 2012
On Fri, Feb 10, 2012 at 9:46 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> Matt,
> until we move to bitbucket - can you continue to push to petsc.cs.iit
> - and not bitbucket? [for now - pushes to petsc.cs.iit are
> automatically pushed to bitbucket]
I thought we were switched already :) I cannot understand why we would not
give up this maintenance burden (and directories is not a good enough
reason).
   Matt
> thanks,
> Satish
> asterix:/home/balay/spetsc>hg in
> running ssh petsc at petsc.cs.iit.edu 'hg -R /hg/petsc/petsc-dev serve
> --stdio'
> comparing with ssh://petsc@petsc.cs.iit.edu//hg/petsc/petsc-dev
> searching for changes
> no changes found
> asterix:/home/balay/spetsc>hg in https://bitbucket.org/petsc/petsc-dev
> comparing with https://bitbucket.org/petsc/petsc-dev
> all local heads known remotely
> changeset:   22123:41a8404903d4
> user:        Matthew G Knepley <knepley at gmail.com>
> date:        Thu Feb 09 18:11:40 2012 -0600
> files:       src/dm/impls/mesh/meshexodus.c
> description:
> Fixed allocation define
> changeset:   22124:e3267d7effd7
> date:        Thu Feb 09 18:13:59 2012 -0600
> files:       config/builder.py src/dm/impls/complex/complex.c
> src/snes/examples/tutorials/ex62.c
> description:
> Reorganizing ex62 tests and fixed global section
> - Things are somewhat broken now
> changeset:   22125:5302f0df1089
> tag:         tip
> date:        Thu Feb 09 19:12:03 2012 -0600
> files:       include/petscdmmesh.hh
> description:
> Small fix to old preallocation
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120210/8bba15fa/attachment.html>
