[petsc-dev] petsc-dev on bitbucket
Fri Feb 10 09:46:35 CST 2012
Matt,
until we move to bitbucket - can you continue to push to petsc.cs.iit
- and not bitbucket? [for now - pushes to petsc.cs.iit are
automatically pushed to bitbucket]
thanks,
Satish
asterix:/home/balay/spetsc>hg in
running ssh petsc at petsc.cs.iit.edu 'hg -R /hg/petsc/petsc-dev serve --stdio'
comparing with ssh://petsc@petsc.cs.iit.edu//hg/petsc/petsc-dev
searching for changes
no changes found
asterix:/home/balay/spetsc>hg in https://bitbucket.org/petsc/petsc-dev
comparing with https://bitbucket.org/petsc/petsc-dev
all local heads known remotely
changeset:   22123:41a8404903d4
user:        Matthew G Knepley <knepley at gmail.com>
date:        Thu Feb 09 18:11:40 2012 -0600
files:       src/dm/impls/mesh/meshexodus.c
description:
Fixed allocation define
changeset:   22124:e3267d7effd7
date:        Thu Feb 09 18:13:59 2012 -0600
files:       config/builder.py src/dm/impls/complex/complex.c src/snes/examples/tutorials/ex62.c
description:
Reorganizing ex62 tests and fixed global section
- Things are somewhat broken now
changeset:   22125:5302f0df1089
tag:         tip
date:        Thu Feb 09 19:12:03 2012 -0600
files:       include/petscdmmesh.hh
description:
Small fix to old preallocation
