[petsc-dev] petsc-dev on bitbucket
Thu Feb 9 21:59:27 CST 2012
On Thu, Feb 9, 2012 at 21:54, Satish Balay <balay at mcs.anl.gov> wrote:
> I interpreted sean as suggesting using 'hg tags' to organize relase patches
> and dev changes in a single repo.
Release and dev in the same clone does not work (and was not suggested)
unless bookmarks are used. Since that isn't familiar to a lot of Hg users,
I'm not suggesting it.
> And instead of using seprate clones
> for releases as we do now - redo the work flow with 'hg tags'
> To me its not easy to implement branches with tags - hence the above
> statement. [either you have named branches or you let the repo have
> multiple heads - and keep tagging the release head and workarround the
> confusion during merges etc. I'd rather deal with these issues in
> separate clones for release/dev]
I think separate clone for release and dev is easy for people to work with.
I think separate clones for every release is clutter.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120209/d0aae054/attachment.html>
