[petsc-dev] petsc-dev on bitbucket
Thu Feb 9 21:54:13 CST 2012
On Thu, 9 Feb 2012, Matthew Knepley wrote:
> On Thu, Feb 9, 2012 at 8:26 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > On Wed, 8 Feb 2012, Sean Farley wrote:
> > > > Hell, if you *really* want to, just create the account:
> > petsc-release(s)
> > > > then the URL would be
> > > > http://bitbucket.org/petsc-release/petsc-3.1
> > > Actually, it's even easier than that:
> > > https://bitbucket.org/petsc/petsc-dev/downloads
> > > which provides downloads for all taged changesets.
> > tags are no good. we implrement branches in different clones.
> I am not sure what you mean by this. Let me be explicit.
> This organization is semantic, and Completely outside the version control
> structure. I want something to tell me "this repo is about simulating
> rockets"
> like Kit, the voice in Michael's car. Tags are fine for this. So is a
> hierarchy.
> So is silly XML metadata.
I interpreted sean as suggesting using 'hg tags' to organize relase patches
and dev changes in a single repo. And instead of using seprate clones
for releases as we do now - redo the work flow with 'hg tags'
To me its not easy to implement branches with tags - hence the above
statement. [either you have named branches or you let the repo have
multiple heads - and keep tagging the release head and workarround the
confusion during merges etc. I'd rather deal with these issues in
separate clones for release/dev]
satish
