[petsc-dev] petsc-dev on bitbucket
Thu Feb 9 21:41:51 CST 2012
On Thu, Feb 9, 2012 at 8:59 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Thu, 9 Feb 2012, Sean Farley wrote:
> > > Hg named branches are kind of screwy and bookmarks (which are less
> screwy)
> > > are still an "extension"
> > This is true. Named branches are directly inherited from older versioning
> > systems (cvs, svn, etc.). After 2.0 Matt Mackall was convinced that
> > bookmarks so be completely analgous to git's branching:
> > $ hg branch foo
> > marked working directory as branch foo
> > (branches are permanent and global, did you want a bookmark?)
> > Mercurial 2.1 includes fixes that move and update bookmarks automatically
> > (and also allow pulling divergent bookmarks: foo at 1, foo at 2)
> > so it makes sense to have separate clones to use for release management.
> > > But these releases get merged back, so just tagging them would place
> the
> > > tarball in the right place.
> > Righto.
> > > But PETSc release tarballs include generated documentation, so using
> > > bitbucket's auto-generated tag-tarballs is not enough for releases.
> > Ah, that's right. I think this could be fixed by using the tag info in
> the
> > scripts that generate the documentation.
> Sure alternatives are possible. I guess the primary question is: is
> are you suggesting this alternate workflow - just becuase its possible
> - or because its better? This conversation started off with solving a
> different problem - and then turned into changing workflow.
> We have a decent workflow currently - and the whole change of workflow
> [eventhough its possible] -I don't think buying us much. And I suspect
> it has additional complexity which some of us don't want to deal with.
I do not understand how this changes workflow. It does not change mine at
all.
My workflow relies on being able to push and pull from repositories. We can
still do this. We do gain reliability, and backups.
Please explain what we cannot do now.
    Matt
> If we have to create multiple accounts to better organize repos - so
> be it..
> Satish
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120209/a456829a/attachment.html>
