[petsc-dev] MatMatMult gives different results
Alexander Grayver agrayver at gfz-potsdam.de
Thu Feb 9 02:25:37 CST 2012
Jed,
Pulled petsc-dev this morning:
[ 63%] Building C object
CMakeFiles/petsc.dir/src/dm/impls/redundant/ftn-auto/dmredundantf.c.o
/home/lib/petsc-dev/src/dm/impls/complex/ftn-auto/complexf.c(125):
error: declaration is incompatible with "PetscErrorCode={int}
DMComplexSetConeOrientation(DM, PetscInt={int}, const PetscInt={int} *)"
(declared at line 29 of "/home/lib/petsc-dev/include/petscdmcomplex.h")
   void PETSC_STDCALL DMComplexSetConeOrientation dmcomplexsetcone_(DM
dm,PetscInt *p, PetscInt coneOrientation[], int *__ierr ){
error: incomplete type is not allowed
error: expected a ";"
/home/lib/petsc-dev/src/dm/impls/complex/ftn-auto/complexf.c(147):
warning #12: parsing restarts here after previous syntax error
[ 63%] compilation aborted for
/home/lib/petsc-dev/src/dm/impls/complex/ftn-auto/complexf.c (code 2)
make[4]: ***
[CMakeFiles/petsc.dir/src/dm/impls/complex/ftn-auto/complexf.c.o] Error 2
make[4]: *** Waiting for unfinished jobs....
Building C object CMakeFiles/petsc.dir/src/dm/impls/da/ftn-custom/zda.c.o
make[3]: *** [CMakeFiles/petsc.dir/all] Error 2
make[2]: *** [all] Error 2
Yesterday's petsc compiled fine.
On 08.02.2012 22:21, Jed Brown wrote:
> On Wed, Feb 8, 2012 at 23:39, Alexander Grayver
> <agrayver at gfz-potsdam.de <mailto:agrayver at gfz-potsdam.de>> wrote:
>     It happens within the CG solver with the system matrix which is
>     created like this:
>     call
>     MatCreateShell(MPI_COMM_WORLD,mlocal,nlocal,N,N,PETSC_NULL_INTEGER,H,ierr);CHKERRQ(ierr)
> This should be fixed in petsc-dev now, can you pull and try again?
Alexander
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120209/8ace540e/attachment.html>
