[petsc-dev] MatMatMult gives different results
Thu Feb 9 02:44:26 CST 2012
This is fixed now.
On Thu, Feb 9, 2012 at 11:25, Alexander Grayver <agrayver at gfz-potsdam.de>wrote:
> Jed,
> Pulled petsc-dev this morning:
> [ 63%] Building C object
> CMakeFiles/petsc.dir/src/dm/impls/redundant/ftn-auto/dmredundantf.c.o
> /home/lib/petsc-dev/src/dm/impls/complex/ftn-auto/complexf.c(125): error:
> declaration is incompatible with "PetscErrorCode={int}
> DMComplexSetConeOrientation(DM, PetscInt={int}, const PetscInt={int} *)"
> (declared at line 29 of "/home/lib/petsc-dev/include/petscdmcomplex.h")
>   void PETSC_STDCALL DMComplexSetConeOrientation dmcomplexsetcone_(DM
> dm,PetscInt *p, PetscInt coneOrientation[], int *__ierr ){
> incomplete type is not allowed
> expected a ";"
> /home/lib/petsc-dev/src/dm/impls/complex/ftn-auto/complexf.c(147): warning
> #12: parsing restarts here after previous syntax error
> [ 63%] compilation aborted for
> /home/lib/petsc-dev/src/dm/impls/complex/ftn-auto/complexf.c (code 2)
> make[4]: ***
> [CMakeFiles/petsc.dir/src/dm/impls/complex/ftn-auto/complexf.c.o] Error 2
> make[4]: *** Waiting for unfinished jobs....
> Building C object CMakeFiles/petsc.dir/src/dm/impls/da/ftn-custom/zda.c.o
> make[3]: *** [CMakeFiles/petsc.dir/all] Error 2
> make[2]: *** [all] Error 2
> Yesterday's petsc compiled fine.
> On 08.02.2012 22:21, Jed Brown wrote:
>  On Wed, Feb 8, 2012 at 23:39, Alexander Grayver <agrayver at gfz-potsdam.de>wrote:
>> It happens within the CG solver with the system matrix which is created
>> like this:
>> call
>> MatCreateShell(MPI_COMM_WORLD,mlocal,nlocal,N,N,PETSC_NULL_INTEGER,H,ierr);CHKERRQ(ierr)
> This should be fixed in petsc-dev now, can you pull and try again?
> Regards,
> Alexander
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120209/a9598163/attachment.html>
