[petsc-dev] MatMatMult gives different results
Wed Feb 8 15:21:26 CST 2012
On Wed, Feb 8, 2012 at 23:39, Alexander Grayver <agrayver at gfz-potsdam.de>wrote:
> It happens within the CG solver with the system matrix which is created
> like this:
> call
> MatCreateShell(MPI_COMM_WORLD,mlocal,nlocal,N,N,PETSC_NULL_INTEGER,H,ierr);CHKERRQ(ierr)
This should be fixed in petsc-dev now, can you pull and try again?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120209/a3a3ed8a/attachment.html>
