[petsc-dev] [petsc-maint #61515] data size of PETSc-dev GPU	computing
    Jed Brown
    jed at 59A2.org
    Wed Jan 19 22:30:23 CST 2011
2011/1/18 Matthew Knepley <knepley at gmail.com>
> This has the EXACT PROBLEM I mailed about last time. Look at your
> file
>   ksp_poisson2d_256_4_with_cuda_view.txt
> It is only 6K. All the others are 14K. It has no information from ksp_view.
That is because it is not converging and was interruped.  Compare to the
smaller problem size where CUDA and non-CUDA converge identically.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110120/6fe6a368/attachment.html>
