[petsc-dev] [petsc-maint #61515] data size of PETSc-dev GPU computing
Tue Jan 18 10:29:57 CST 2011
On Mon, Jan 17, 2011 at 10:49 PM, <li.luo at siat.ac.cn> wrote:
> Hi, Barry.
> I have tested several example, with the same problem.
> The attachments are result for ex2 in \ksp\examples\tutorials,
> 4GPU-4CPU, different grid size: 128*128, 256*256; with or without CUDA.
> You may see the view of KSP, summary log, and database options line.
> The result is,
> for 128*128, both with an without CUDA, converge.
> for 256*256, only without CUDA converge.
This has the EXACT PROBLEM I mailed about last time. Look at your
file
  ksp_poisson2d_256_4_with_cuda_view.txt
It is only 6K. All the others are 14K. It has no information from ksp_view.
   Matt
> Thanks for your help
> Regards,
> Li Luo
> > -----原始邮件-----
> > 发件人: "Barry Smith" <bsmith at mcs.anl.gov>
> > 发送时间: 2011年1月18日 星期二
> > 收件人: petsc-maint <petsc-maint at mcs.anl.gov>, li.luo at siat.ac.cn, "For
> users of the development version of PETSc" <petsc-dev at mcs.anl.gov>
> > 抄送:
> > 主题: Re: [petsc-maint #61515] data size of PETSc-dev GPU computing
> >   Hmm, could be a bug, could be the algorithm. Run with -ksp_view and
> send the output
> >   What problem are you solving, is it a PETSc example?
> >   Barry
> > On Jan 17, 2011, at 8:31 PM, li.luo at siat.ac.cn wrote:
> > > Hi,
> > > I met a problem when testing some examples on PETSc-dev for GPU
> computing,
> > > that is, if one proc pair(1GPU-1CPU) is used, the grid size can be
> enlarged to even 2048*2048, the memory limitation;
> > > however, if more than one proc pairs are use, for example 4GPU-4CPU,
> the grid size is limited to about 200*200, if larger, the ksp solver would
> not converge. The same problem happens to 8GPU-8CPU limited by 500*500 or
> other size.
> > > I wonder whether you have the same problem? Any error happens to type
> MPICUDA?
> > > Regards,
> > > Li Luo
> > >>> # Machine type:
> > >>> CPU:  Intel(R) Xeon(R) CPU E5520
> > >>> GPU: Tesla T10
> > >>> CUDA Driver Version:                           3.20
> > >>> CUDA Capability Major/Minor version number:    1.3
> > >>> # OS Version:
> > >>> Linux console 2.6.18-128.el5 #1 SMP Wed Dec 17 11:41:38 EST 2008
> x86_64 x86_64 x86_64 GNU/Linux
> > >>> # PETSc Version:
> > >>> #define PETSC_VERSION_RELEASE    0
> > >>> #define PETSC_VERSION_MAJOR      3
> > >>> #define PETSC_VERSION_MINOR      1
> > >>> #define PETSC_VERSION_SUBMINOR   0
> > >>> #define PETSC_VERSION_PATCH      6
> > >>> #define PETSC_VERSION_DATE       "Mar, 25, 2010"
> > >>> #define PETSC_VERSION_PATCH_DATE "Thu Dec  9 00:02:47 CST 2010"
> > >>> # MPI implementation:
> > >>> ictce3.2/impi/3.2.0.011/
> > >>> # Compiler:
> > >>> # Probable PETSc component:
> > >>> run with GPU
> > >>> # Configure
> > >>> ./config/configure.py  --download-f-blas-lapack=1
> --with-mpi-dir=/bwfs/software/mpich2-1.2.1p1 --with-shared-libraries=0
> --with-debugging=no --with-cuda-dir=/bwfs/home/liluo/cuda3.2_64
> --with-thrust-dir=/bwfs/home/liluo/cuda3.2_64/include/thrust
> --with-cusp-dir=/bwfs/home/liluo/cuda3.2_64/include/cusp-library
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20110118/2a24dd40/attachment.html>
