[petsc-dev] PaStiX solution
Wed Dec 28 09:27:00 CST 2011
On Wed, Dec 28, 2011 at 09:10, Alexander Grayver <agrayver at gfz-potsdam.de>wrote:
> So if I understood it right, I put diff you gave in file pastix_patch in
> petsc-dev dir and called:
> lib/petsc-dev> patch -Np1 < pastix_patch
> And built petsc again. Now
> lib/petsc-dev> hg diff src/mat/impls/aij/mpi/pastix/pastix.c
Yes, the patch applied correctly.
> So I guess it's patched correctly?
> Because I don't see much difference in output. Please find it attached.
> Did I make something wrong?
Hmm, it is hard-coded to say that the matrix is symmetric. We are setting
API_FACT_LU (you could check that it has not been changed by attaching a
debugger in MatFactorNumeric_PaStiX and printing
lu->iparm[IPARM_FACTORIZATION]). Maybe PaStiX is ignoring this and always
doing LLt instead. We probably need to set API_PARM_LDLT (and possibly
API_PARM_LU, but they claim that only does static pivoting, which might
still be a problem). You could try adding this to
src/mat/impls/aij/mpi/pastix/pastix.c or ask the PaStiX developers what
they suggest for symmetric indefinite systems.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111228/4dbfe7d0/attachment.html>
