[petsc-dev] PaStiX solution
Alexander Grayver agrayver at gfz-potsdam.de
Wed Dec 28 09:10:31 CST 2011
So if I understood it right, I put diff you gave in file pastix_patch in
petsc-dev dir and called:
lib/petsc-dev> patch -Np1 < pastix_patch
And built petsc again. Now
lib/petsc-dev> hg diff src/mat/impls/aij/mpi/pastix/pastix.c
diff -r 3286696bb4a0 src/mat/impls/aij/mpi/pastix/pastix.c
--- a/src/mat/impls/aij/mpi/pastix/pastix.c     Tue Dec 27 11:43:50 2011
-0600
+++ b/src/mat/impls/aij/mpi/pastix/pastix.c     Wed Dec 28 16:05:21 2011
+0100
@@ -446,16 +446,6 @@
      ierr = PetscMalloc((lu->n)*sizeof(PetscInt)
,&(lu->invp));CHKERRQ(ierr);
-  if (isSym) {
-    /* On symmetric matrix, LLT */
-    lu->iparm[IPARM_SYM] = API_SYM_YES;
-    lu->iparm[IPARM_FACTORIZATION] = API_FACT_LDLT;
-  } else {
-    /* On unsymmetric matrix, LU */
-    lu->iparm[IPARM_SYM] = API_SYM_NO;
-    lu->iparm[IPARM_FACTORIZATION] = API_FACT_LU;
    if (lu->matstruc == DIFFERENT_NONZERO_PATTERN){
      if (!(isSeqAIJ || isSeqSBAIJ)) {
@@ -529,7 +519,7 @@
    PetscFunctionBegin;
+  lu->iparm[IPARM_SYM]           = API_SYM_NO;
    lu->matstruc                   = DIFFERENT_NONZERO_PATTERN;
    F->ops->lufactornumeric        = MatFactorNumeric_PaStiX;
    PetscFunctionReturn(0);
@@ -545,7 +535,7 @@
    PetscFunctionBegin;
    lu->iparm[IPARM_FACTORIZATION]  = API_FACT_LLT;
+  lu->iparm[IPARM_SYM]            = API_SYM_YES;
    (F)->ops->choleskyfactornumeric = MatFactorNumeric_PaStiX;
So I guess it's patched correctly?
Because I don't see much difference in output. Please find it attached.
Did I make something wrong?
Alexander
On 28.12.2011 15:26, Jed Brown wrote:
> On Wed, Dec 28, 2011 at 08:11, Alexander Grayver
> <agrayver at gfz-potsdam.de <mailto:agrayver at gfz-potsdam.de>> wrote:
>     I tried LU, the result is the same (attached). The matrix is
>     recognized as a symmetric, even though I put in the code:
>         ierr = MatSetOption(A,MAT_SYMMETRIC,PETSC_FALSE);
>         ierr = MatSetOption(A,MAT_SPD,PETSC_FALSE);
>     Seems like internal check?
>     I checked positive-definiteness of the matrix in matlab (using
>     [L,p,s] = chol(A); test) and it's not SPD.
>     So it seems like PaStiX is not very robust. This case is not one
>     inch close to the bad cases I used MUMPS with.
> Just for kicks, can you try making the change below and re-running
> your tests with LU? This is code that the PaStiX developers sent, but
> it doesn't make sense to me as written.
> $ hg diff src/mat/impls/aij/mpi/pastix/pastix.c
> -  if (isSym) {
> -  } else {
> @@ -529,7 +519,7 @@
>    PetscFunctionBegin;
> @@ -545,7 +535,7 @@
>    PetscFunctionBegin;
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111228/1ebb53dd/attachment.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111228/1ebb53dd/attachment.txt>
