[petsc-dev] PaStiX solution
Alexander Grayver agrayver at gfz-potsdam.de
Wed Dec 28 10:12:46 CST 2011
On 28.12.2011 16:27, Jed Brown wrote:
> On Wed, Dec 28, 2011 at 09:10, Alexander Grayver
> <agrayver at gfz-potsdam.de <mailto:agrayver at gfz-potsdam.de>> wrote:
>     So if I understood it right, I put diff you gave in file
>     pastix_patch in petsc-dev dir and called:
>     lib/petsc-dev> patch -Np1 < pastix_patch
>     And built petsc again. Now
>     lib/petsc-dev> hg diff src/mat/impls/aij/mpi/pastix/pastix.c
> Yes, the patch applied correctly.
>     So I guess it's patched correctly?
>     Because I don't see much difference in output. Please find it
>     attached.
>     Did I make something wrong?
> Hmm, it is hard-coded to say that the matrix is symmetric. We are
> setting API_FACT_LU (you could check that it has not been changed by
> attaching a debugger in MatFactorNumeric_PaStiX and printing
> lu->iparm[IPARM_FACTORIZATION]). Maybe PaStiX is ignoring this and
> always doing LLt instead.
No. I checked, the API_FACT_LU is set correctly.
> We probably need to set API_PARM_LDLT (and possibly API_PARM_LU, but
> they claim that only does static pivoting, which might still be a
> problem). You could try adding this to
> src/mat/impls/aij/mpi/pastix/pastix.c or ask the PaStiX developers
> what they suggest for symmetric indefinite systems.
I tried API_PARM_LDLT, but it has no effect.
Thanks for help, I will consider writing PaStiX team.
Alexander
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111228/564fee4e/attachment.html>
