[petsc-dev] Non-scalable matrix operations
Mark F. Adams mark.adams at columbia.edu
Fri Dec 23 13:43:16 CST 2011
I was assuming context data was stuffed in a Mat.  So whatever your context object is can be used in the solve phase, just passed through to the apply operator.  A graph is just needed for setup, for the ISs.
On Dec 23, 2011, at 2:33 PM, Jed Brown wrote:
> On Fri, Dec 23, 2011 at 13:31, Mark F. Adams <mark.adams at columbia.edu> wrote:
> Ah yes, by "mat" I'm assuming a shell in this case.  The construction of these ISs needs a graph -- its not magic -- its a parallel multiplicative method.
> Yes, the user should provide a Mat so that the library can build the ISs, but the user shouldn't get a Mat back in their callback because they are being asked to perform a nonlinear operation that does not use a Mat.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111223/d356c58b/attachment.html>
