[petsc-dev] Non-scalable matrix operations
Fri Dec 23 13:33:49 CST 2011
On Fri, Dec 23, 2011 at 13:31, Mark F. Adams <mark.adams at columbia.edu>wrote:
> Ah yes, by "mat" I'm assuming a shell in this case.  The construction of
> these ISs needs a graph -- its not magic -- its a parallel multiplicative
> method.
Yes, the user should provide a Mat so that the library can build the ISs,
but the user shouldn't get a Mat back in their callback because they are
being asked to perform a nonlinear operation that does not use a Mat.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111223/38ca3854/attachment.html>
