[petsc-dev] Non-scalable matrix operations
Mark F. Adams mark.adams at columbia.edu
Fri Dec 23 13:11:30 CST 2011
On Dec 23, 2011, at 1:24 PM, Jed Brown wrote:
> On Fri, Dec 23, 2011 at 12:19, Mark F. Adams <mark.adams at columbia.edu> wrote:
> Eisenstat is not computing with zero data if there is no initial guess, right?  I'm not sure I understand you here.
> I'm thinking of, e.g. third order Cheby preconditioned by GS.
And so you would always have a zero initial guess ... this is messy to implement but it could be done.
>> I know the theory doesn't argue for it, but G-S with Cheby sometimes wins over everything else I've tried.
> People damp G-S for convection etc, which is what Cheb/GS does.  Do you do this for SPD systems?
> No, I was doing it for the thermo/lid-driven cavity, for example.
>> Is there any hope of doing nonlinear G-S where the user can provide something moderately simple?
> Nonlinear should be very simple actually.  Just replace my hacks into (MPI)AIJ matrices with your own operator.
> Sure, but what does the user need to provide? How much code can we reuse between the matrix-based implementation and the nonlinear implementation?
You just have to provide a method like
int applyGS( Mat mat, Vec lhs, Vec rhs, IS eqs, Bool reverse)
that applies G-S to the local rows in "eqs" and processes them in reverse order if "reverse" is true.  Reverse is just to symmetrize the operator.  Since this is probably best used for non-symetric operators we could simplify the algorithm a bit and get rid of this ...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111223/56c7557c/attachment.html>
