[petsc-dev] Non-scalable matrix operations
Fri Dec 23 13:17:01 CST 2011
On Fri, Dec 23, 2011 at 13:11, Mark F. Adams <mark.adams at columbia.edu>wrote:
> Sure, but what does the user need to provide? How much code can we reuse
> between the matrix-based implementation and the nonlinear implementation?
> You just have to provide a method like
> int applyGS( Mat mat, Vec lhs, Vec rhs, IS eqs, Bool reverse)
> that applies G-S to the local rows in "eqs" and processes them in reverse
> order if "reverse" is true.  Reverse is just to symmetrize the operator.
>  Since this is probably best used for non-symetric operators we could
> simplify the algorithm a bit and get rid of this ...
Sure, so this update lhs for some equations, but there is no Mat (because
it's nonlinear). To create the ISs, we'll have to specify the connections
between nodes (could use a matrix to denote that).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111223/2afa607b/attachment.html>
