[petsc-dev] Non-scalable matrix operations
Fri Dec 23 12:24:45 CST 2011
On Fri, Dec 23, 2011 at 12:19, Mark F. Adams <mark.adams at columbia.edu>wrote:
> Eisenstat is not computing with zero data if there is no initial guess,
> right?  I'm not sure I understand you here.
I'm thinking of, e.g. third order Cheby preconditioned by GS.
> I know the theory doesn't argue for it, but G-S with Cheby sometimes wins
> over everything else I've tried.
> People damp G-S for convection etc, which is what Cheb/GS does.  Do you do
> this for SPD systems?
No, I was doing it for the thermo/lid-driven cavity, for example.
> Is there any hope of doing nonlinear G-S where the user can provide
> something moderately simple?
> Nonlinear should be very simple actually.  Just replace my hacks into
> (MPI)AIJ matrices with your own operator.
Sure, but what does the user need to provide? How much code can we reuse
between the matrix-based implementation and the nonlinear implementation?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111223/24e45bf8/attachment.html>
