[petsc-dev] CMake version
Alexander Grayver agrayver at gfz-potsdam.de
Fri Dec 9 09:37:23 CST 2011
Thanks Satish!
Works well.
On 09.12.2011 16:12, Satish Balay wrote:
> pushed a fix for this issue.
> Satish
> On Fri, 9 Dec 2011, Satish Balay wrote:
>> for now you should be able to use --download-cmake. Will check why the
>> cmake from PATH is not working..
>> Satish
>> On Fri, 9 Dec 2011, Alexander Grayver wrote:
>>> I installed cmake 2.8.6 in my local directory and petsc sees it there, but
>>> still gives same error:
>>>      Defined make macro "CMAKE " to "/home/bin/cmake/bin/cmake"
>>>      Pushing language C
>>> TEST configureLibrary from
>>> PETSc.packages.metis(/home/lib/petsc-dev/config/BuildSystem/config/package.py:417)
>>> TESTING: configureLibrary from
>>> PETSc.packages.metis(config/BuildSystem/config/package.py:417)
>>>    Find an installation and check if it can work with PETSc
>>>        Checking for a functional metis
>>>                Looking for METIS in directory starting with metis
>>>                Found a copy of METIS in metis-5.0.2
>>>           UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
>>> details):
>>> CMake>  2.8.5 is needed to build METIS
>>>    File "/home/lib/petsc-dev/config/configure.py", line 287, in petsc_configure
>>>      framework.configure(out = sys.stdout)
>>>    File "/home/lib/petsc-dev/config/BuildSystem/config/framework.py", line 929,
>>> in configure
>>>      child.configure()
>>>    File "/home/lib/petsc-dev/config/BuildSystem/config/package.py", line 506,
>>> in configure
>>>      self.executeTest(self.configureLibrary)
>>>    File "/home/lib/petsc-dev/config/BuildSystem/config/base.py", line 115, in
>>> executeTest
>>>      ret = apply(test, args,kargs)
>>>    File "/home/lib/petsc-dev/config/BuildSystem/config/package.py", line 433,
>>> in configureLibrary
>>>      for location, directory, lib, incl in self.generateGuesses():
>>>    File "/home/lib/petsc-dev/config/BuildSystem/config/package.py", line 228,
>>> in generateGuesses
>>>      d = self.checkDownload(1)
>>>    File "/home/lib/petsc-dev/config/BuildSystem/config/package.py", line 313,
>>> in checkDownload
>>>      return self.getInstallDir()
>>>    File "/home/lib/petsc-dev/config/BuildSystem/config/package.py", line 183,
>>> in getInstallDir
>>>      return os.path.abspath(self.Install())
>>>    File "/home/lib/petsc-dev/config/PETSc/packages/metis.py", line 30, in
>>> Install
>>>      raise RuntimeError('CMake>  2.8.5 is needed to build METIS')
>>> lib/petsc-dev>  cmake -version
>>> cmake version 2.8.6
>>> On 09.12.2011 09:56, Alexander Grayver wrote:
>>>> Hi dev-team,
>>>> Yesterday I duilt petsc-dev successfully, today I updated it and tried to
>>>> reconfigure:
>>>> cmake version 2.8.4
>>>> Just tell me, something has been changed in petsc or it's rather my machine?
>>>> Regards,
>>>> Alexander
