[petsc-dev] CHOLESKY with MUMPS doesn't work properly
Alexander Grayver agrayver at gfz-potsdam.de
Fri Dec 9 10:31:54 CST 2011
Hi dev-team,
I have this code:
   call KSPCreate(comm3d,ksp,ierr);CHKERRQ(ierr)
   call
KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN,ierr);CHKERRQ(ierr)
   call KSPSetType(ksp,KSPPREONLY,ierr);CHKERRQ(ierr)
   call KSPGetPC(ksp,pc,ierr);CHKERRQ(ierr)
   call PCSetType(pc,PCCHOLESKY,ierr);CHKERRQ(ierr)
   call PCFactorSetMatSolverPackage(pc,MATSOLVERMUMPS,ierr);CHKERRQ(ierr)
   call PCFactorSetUpMatSolverPackage(pc,ierr);CHKERRQ(ierr)
   call PCFactorGetMatrix(pc,F,ierr);CHKERRQ(ierr)
which works well under petsc-3.2-p5, but produces error with petsc-dev:
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: No support for this operation for this object type!
[0]PETSC ERROR: Matrix format mpiaij does not have a built-in PETSc
CHOLESKY!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Development HG revision:
a4f22f4fcb371a016e046e537076dcfd2ce5087f  HG Date: Fri Dec 09 09:08:30
2011 -0600
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: /home/model on a openmpi-i named node233 by agrayver Fri
Dec  9 17:23:30 2011
[0]PETSC ERROR: Libraries linked from
/home/lib/petsc-dev/openmpi-intel-complex-release-f-ds/lib
[0]PETSC ERROR: Configure run at Fri Dec  9 16:51:10 2011
[0]PETSC ERROR: Configure options --download-metis --download-mumps
--download-parmetis --download-superlu_dist
--with-blacs-include=/opt/intel/Compiler/11.1/072/mkl/include
--with-blacs-lib=/opt/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_blacs_openmpi_lp64.a
--with-blas-lapack-dir=/opt/intel/Compiler/11.1/072/mkl/lib/em64t
--with-debugging=0 --with-fortran-interfaces=1 --with-fortran-kernels=1
--with-mpi-dir=/opt/mpi/intel/openmpi-1.4.2
--with-petsc-arch=openmpi-intel-complex-release-f-ds
--with-precision=double
--with-scalapack-include=/opt/intel/Compiler/11.1/072/mkl/include
--with-scalapack-lib=/opt/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_scalapack_lp64.a
--with-scalar-type=complex --with-x=0
PETSC_ARCH=openmpi-intel-complex-release-f-ds
[0]PETSC ERROR:
[0]PETSC ERROR: MatGetFactor() line 3943 in
/home/lib/petsc-dev/src/mat/interface/matrix.c
[0]PETSC ERROR: PCFactorSetUpMatSolverPackage_Factor() line 17 in
/home/lib/petsc-dev/src/ksp/pc/impls/factor/factimpl.c
[0]PETSC ERROR: PCFactorSetUpMatSolverPackage() line 26 in
/home/lib/petsc-dev/src/ksp/pc/impls/factor/factor.c
Any idea?
Alexander
