[petsc-dev] CMake version
Fri Dec 9 09:12:52 CST 2011
pushed a fix for this issue.
Satish
On Fri, 9 Dec 2011, Satish Balay wrote:
> for now you should be able to use --download-cmake. Will check why the
> cmake from PATH is not working..
> Satish
> On Fri, 9 Dec 2011, Alexander Grayver wrote:
> > I installed cmake 2.8.6 in my local directory and petsc sees it there, but
> > still gives same error:
> >     Defined make macro "CMAKE " to "/home/bin/cmake/bin/cmake"
> >     Pushing language C
> > TEST configureLibrary from
> > PETSc.packages.metis(/home/lib/petsc-dev/config/BuildSystem/config/package.py:417)
> > TESTING: configureLibrary from
> > PETSc.packages.metis(config/BuildSystem/config/package.py:417)
> >   Find an installation and check if it can work with PETSc
> >       Checking for a functional metis
> >               Looking for METIS in directory starting with metis
> >               Found a copy of METIS in metis-5.0.2
> >          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> > details):
> > CMake > 2.8.5 is needed to build METIS
> >   File "/home/lib/petsc-dev/config/configure.py", line 287, in petsc_configure
> >     framework.configure(out = sys.stdout)
> >   File "/home/lib/petsc-dev/config/BuildSystem/config/framework.py", line 929,
> > in configure
> >     child.configure()
> >   File "/home/lib/petsc-dev/config/BuildSystem/config/package.py", line 506,
> > in configure
> >     self.executeTest(self.configureLibrary)
> >   File "/home/lib/petsc-dev/config/BuildSystem/config/base.py", line 115, in
> > executeTest
> >     ret = apply(test, args,kargs)
> >   File "/home/lib/petsc-dev/config/BuildSystem/config/package.py", line 433,
> > in configureLibrary
> >     for location, directory, lib, incl in self.generateGuesses():
> >   File "/home/lib/petsc-dev/config/BuildSystem/config/package.py", line 228,
> > in generateGuesses
> >     d = self.checkDownload(1)
> >   File "/home/lib/petsc-dev/config/BuildSystem/config/package.py", line 313,
> > in checkDownload
> >     return self.getInstallDir()
> >   File "/home/lib/petsc-dev/config/BuildSystem/config/package.py", line 183,
> > in getInstallDir
> >     return os.path.abspath(self.Install())
> >   File "/home/lib/petsc-dev/config/PETSc/packages/metis.py", line 30, in
> > Install
> >     raise RuntimeError('CMake > 2.8.5 is needed to build METIS')
> > lib/petsc-dev> cmake -version
> > cmake version 2.8.6
> > On 09.12.2011 09:56, Alexander Grayver wrote:
> > > Hi dev-team,
> > > Yesterday I duilt petsc-dev successfully, today I updated it and tried to
> > > reconfigure:
> > > cmake version 2.8.4
> > > Just tell me, something has been changed in petsc or it's rather my machine?
> > > Regards,
> > > Alexander
