[petsc-dev] CMake version
Fri Dec 9 08:43:28 CST 2011
for now you should be able to use --download-cmake. Will check why the
cmake from PATH is not working..
Satish
On Fri, 9 Dec 2011, Alexander Grayver wrote:
> I installed cmake 2.8.6 in my local directory and petsc sees it there, but
> still gives same error:
>     Defined make macro "CMAKE " to "/home/bin/cmake/bin/cmake"
>     Pushing language C
> TEST configureLibrary from
> PETSc.packages.metis(/home/lib/petsc-dev/config/BuildSystem/config/package.py:417)
> TESTING: configureLibrary from
> PETSc.packages.metis(config/BuildSystem/config/package.py:417)
>   Find an installation and check if it can work with PETSc
>       Checking for a functional metis
>               Looking for METIS in directory starting with metis
>               Found a copy of METIS in metis-5.0.2
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> details):
> CMake > 2.8.5 is needed to build METIS
>   File "/home/lib/petsc-dev/config/configure.py", line 287, in petsc_configure
>     framework.configure(out = sys.stdout)
>   File "/home/lib/petsc-dev/config/BuildSystem/config/framework.py", line 929,
> in configure
>     child.configure()
>   File "/home/lib/petsc-dev/config/BuildSystem/config/package.py", line 506,
> in configure
>     self.executeTest(self.configureLibrary)
>   File "/home/lib/petsc-dev/config/BuildSystem/config/base.py", line 115, in
> executeTest
>     ret = apply(test, args,kargs)
>   File "/home/lib/petsc-dev/config/BuildSystem/config/package.py", line 433,
> in configureLibrary
>     for location, directory, lib, incl in self.generateGuesses():
>   File "/home/lib/petsc-dev/config/BuildSystem/config/package.py", line 228,
> in generateGuesses
>     d = self.checkDownload(1)
>   File "/home/lib/petsc-dev/config/BuildSystem/config/package.py", line 313,
> in checkDownload
>     return self.getInstallDir()
>   File "/home/lib/petsc-dev/config/BuildSystem/config/package.py", line 183,
> in getInstallDir
>     return os.path.abspath(self.Install())
>   File "/home/lib/petsc-dev/config/PETSc/packages/metis.py", line 30, in
> Install
>     raise RuntimeError('CMake > 2.8.5 is needed to build METIS')
> lib/petsc-dev> cmake -version
> cmake version 2.8.6
> On 09.12.2011 09:56, Alexander Grayver wrote:
> > Hi dev-team,
> > Yesterday I duilt petsc-dev successfully, today I updated it and tried to
> > reconfigure:
> > cmake version 2.8.4
> > Just tell me, something has been changed in petsc or it's rather my machine?
> > Regards,
> > Alexander
