[petsc-dev] CMake version
Alexander Grayver agrayver at gfz-potsdam.de
Fri Dec 9 03:43:16 CST 2011
I installed cmake 2.8.6 in my local directory and petsc sees it there,
but still gives same error:
     Defined make macro "CMAKE " to "/home/bin/cmake/bin/cmake"
     Pushing language C
TEST configureLibrary from
PETSc.packages.metis(/home/lib/petsc-dev/config/BuildSystem/config/package.py:417)
TESTING: configureLibrary from
PETSc.packages.metis(config/BuildSystem/config/package.py:417)
   Find an installation and check if it can work with PETSc
       Checking for a functional metis
               Looking for METIS in directory starting with metis
               Found a copy of METIS in metis-5.0.2
          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
for details):
CMake > 2.8.5 is needed to build METIS
   File "/home/lib/petsc-dev/config/configure.py", line 287, in
petsc_configure
     framework.configure(out = sys.stdout)
   File "/home/lib/petsc-dev/config/BuildSystem/config/framework.py",
line 929, in configure
     child.configure()
   File "/home/lib/petsc-dev/config/BuildSystem/config/package.py", line
506, in configure
     self.executeTest(self.configureLibrary)
   File "/home/lib/petsc-dev/config/BuildSystem/config/base.py", line
115, in executeTest
     ret = apply(test, args,kargs)
433, in configureLibrary
     for location, directory, lib, incl in self.generateGuesses():
228, in generateGuesses
     d = self.checkDownload(1)
313, in checkDownload
     return self.getInstallDir()
183, in getInstallDir
     return os.path.abspath(self.Install())
   File "/home/lib/petsc-dev/config/PETSc/packages/metis.py", line 30,
in Install
     raise RuntimeError('CMake > 2.8.5 is needed to build METIS')
lib/petsc-dev> cmake -version
cmake version 2.8.6
On 09.12.2011 09:56, Alexander Grayver wrote:
> Hi dev-team,
> Yesterday I duilt petsc-dev successfully, today I updated it and tried
> to reconfigure:
> cmake version 2.8.4
> Just tell me, something has been changed in petsc or it's rather my
> machine?
> Regards,
> Alexander
