[petsc-dev] XDMF viewers
Sat Dec 3 15:25:19 CST 2011
On Sat, Dec 3, 2011 at 3:24 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Sat, Dec 3, 2011 at 15:20, Matthew Knepley <knepley at gmail.com> wrote:
>> Does that matter? The same things are stored at each step.
> Sure (if the mesh doesn't change, which is okay with me now), but you have
> to put the data somewhere. I don't see how you would do that with the
> current API, but it should be simple to accommodate.
Brad did it, but I believe he uses HDF5 attributes
  Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111203/fccaf77d/attachment.html>
