[petsc-dev] XDMF viewers
Sat Dec 3 15:24:08 CST 2011
On Sat, Dec 3, 2011 at 15:20, Matthew Knepley <knepley at gmail.com> wrote:
> Does that matter? The same things are stored at each step.
Sure (if the mesh doesn't change, which is okay with me now), but you have
to put the data somewhere. I don't see how you would do that with the
current API, but it should be simple to accommodate.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20111203/68eee78f/attachment.html>
