[petsc-dev] Handling ADD_VALUES with DMComposite
Jed Brown jed at 59A2.org
Tue Nov 16 12:16:37 CST 2010
Barry, INSERT_VALUES is currently hard-coded.  When we talked at the lab,
you seemed rather down on using DMComposite, but I don't see a good
alternative for e.g. equations in a volume coupled to equations on the
surface.  In any case, should DMCompositeGather() take an InsertMode
argument?  Or is there a different way you had in mind?
Jed
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101116/6eb0e578/attachment.html>
