[petsc-dev] trouble building petsc4py-dev
Mon Nov 15 16:51:13 CST 2010
   Before actually running the cythonize petsc4py should check that the cython version is "good enough" and print a helpful error message otherwise. It should not rely on the "send complaining email; get response email telling to upgrade package X" model of version control. Recommend you add this check.
    Barry
On Nov 15, 2010, at 4:35 PM, Lisandro Dalcin wrote:
> On 15 November 2010 18:56, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>  After manually removing petsc4py.PETSc.c in petsc4py-dev with petsc-dev I get
>> src/PETSc.c:3:28: error: petsc4py.PETSc.c: No such file or directory
>> cythonizing 'src/petsc4py.PETSc.pyx' source
>> Error converting Pyrex file to C:
>>        if o != NULL:
>>            CHKERR( PetscObjectReference(o) )
>>        obj.obj[0] = o
>>        return obj
>>    def __deepcopy__(self, dict memo not None):
>> /Users/barrysmith/Src/petsc-dev/externalpackages/petsc4py/src/PETSc/Object.pyx:34:4: Only extension type arguments can have 'not None'
>> make[1]: *** [petsc4py] Error 1
> Please upgrade Cython to version 0.13.
> Lisandro Dalcin
> CIMEC (INTEC/CONICET-UNL)
> Predio CONICET-Santa Fe
> Colectora RN 168 Km 472, Paraje El Pozo
> Tel: +54-342-4511594 (ext 1011)
> Tel/Fax: +54-342-4511169
