[petsc-dev] error with build
Mon Nov 15 15:21:55 CST 2010
   It will run cython the FIRST time after a clone but not after a hg pull. Which is wrong.  I would like to see this code check if it is a .hg repository (for example) and always run cython in that case.
   Lisandro, is that something that could be added?
    Barry
def run_cython(source):
    import sys, os
    source_c = os.path.splitext(source)[0] + '.c'
    if (os.path.exists(source_c)):
        return False
    try:
        import Cython
    except ImportError:
        warn = lambda msg='': sys.stderr.write(msg+'\n')
        warn("*"*80)
        warn()
        warn(" You need to generate C source files with Cython!!")
        warn(" Download and install Cython <http://www.cython.org>")
        warn()
        warn("*"*80)
        raise SystemExit
    from distutils import log
    from conf.cythonize import run as cythonize
    log.info("cythonizing '%s' source" % source)
    cythonize(source)
    return True
On Nov 15, 2010, at 3:18 PM, Barry Smith wrote:
> On Nov 15, 2010, at 3:15 PM, Satish Balay wrote:
>> Note: you might need latest cython installed on your machine - and do:
>> 'make cython' in petsc4py-dev [before its useable by petsc configure]
>   Crap that make cython business should be done automatically now! If it is not that is bad! petsc4py-dev should locate cython and use it if it finds it.
>   Barry
>> Satish
>> On Mon, 15 Nov 2010, Barry Smith wrote:
>>>  There (sadly) is not completely automatic way to do this. Cd to $PETSC_DIR/externalpackages; remove any petsc4py* directories from there; clone petsc4py-dev into that directory. cd back to $PETSC_DIR; now run ./configure --download-petsc4py
>>>  It will not go and get a copy of petsc4py since the petsc4py-dev directory exists, rather it will use the one you have put there (by your clone).
>>>  Note that petsc4py-dev may not always have been updated to the latest changes to petsc-dev, if you get errors in the build report them to petsc-maint at mcs.anl.gov and we'll update the petsc4py-dev; note that after an update of petsc4py-dev you should cd externalpackages/petsc4py-dev and hg pull; hg update to get the latest.
>>> Yes, someone should add proper support for ./configure to handle hg repositories from petsc-dev and do the pulls and updates automatically but that code has not been written, hence the manual process.
>>>  Barry
>>> On Nov 15, 2010, at 3:00 PM, Srinath Vadlamani wrote:
>>>> How does one configure petsc-dev to build petsc4py-dev?
>>>> I cloned petsc4py-dev but it needs my petsc-dev complex install to have petsc4py symbols?
>>>> <>Srinath
>>>> 2010/11/15 Satish Balay <balay at mcs.anl.gov>
>>>> [original e-mail didnt make it to the list due to the attached
>>>> configure.log. Huge attachments are prohibited on the mailing lists]
>>>> Using configure Options: --with-petsc-arch=real-par-debug --with-scalar-type=real --with-debugging=yes --with-debugger=totalview --download-superlu_dist=1 --download-mumps=1 --download-spooles=1 --with-shared=1 --download-blacs=1 --download-parmetis=1 --download-szip=1 --download-scalapack=1 --download-petsc4py --download-mpi4py --with-shared-libraries -prefix=/Users/srinath/software/petsc-dev-real-par
>>>> petsc4py listed in petsc4py.py is
>>>> http://petsc4py.googlecode.com/files/petsc4py-1.1.1.tar.gz Perhaps you
>>>> have to use petsc-4py-dev directly to get this working?
>>>> Lisandro will know..
>>>> Satish
>>>> On Mon, 15 Nov 2010, Srinath Vadlamani wrote:
>>>>> In file included from src/PETSc.c:3:
>>>>> src/petsc4py.PETSc.c: In function
>>>>> ‘__pyx_pf_8petsc4py_5PETSc_2IS_getBlockSize’:
>>>>> src/petsc4py.PETSc.c:49179: warning: implicit declaration of function
>>>>> ‘ISBlock’
>>>>> src/petsc4py.PETSc.c: In function ‘__pyx_pf_8petsc4py_5PETSc_2IS_getInfo’:
>>>>> src/petsc4py.PETSc.c:51132: warning: implicit declaration of function
>>>>> ‘ISStride’
>>>>> src/petsc4py.PETSc.c: In function ‘__pyx_pf_8petsc4py_5PETSc_3Mat_zeroRows’:
>>>>> src/petsc4py.PETSc.c:75725: error: too few arguments to function
>>>>> ‘MatZeroRowsIS’
>>>>> src/petsc4py.PETSc.c:75750: error: too few arguments to function
>>>>> ‘MatZeroRows’
>>>>> ‘__pyx_pf_8petsc4py_5PETSc_3Mat_zeroRowsLocal’:
>>>>> src/petsc4py.PETSc.c:75872: error: too few arguments to function
>>>>> ‘MatZeroRowsLocalIS’
>>>>> src/petsc4py.PETSc.c:75897: error: too few arguments to function
>>>>> ‘MatZeroRowsLocal’
>>>>> ‘__pyx_pf_8petsc4py_5PETSc_3KSP_setConvergenceTest’:
>>>>> src/petsc4py.PETSc.c:87471: error: ‘KSP_NORM_NO’ undeclared (first use in
>>>>> this function)
>>>>> src/petsc4py.PETSc.c:87471: error: (Each undeclared identifier is reported
>>>>> only once
>>>>> src/petsc4py.PETSc.c:87471: error: for each function it appears in.)
>>>>> ‘__pyx_pf_8petsc4py_5PETSc_3KSP_getNormType’:
>>>>> src/petsc4py.PETSc.c:88847: error: ‘KSP_NORM_NO’ undeclared (first use in
>>>>> this function)
>>>>> src/petsc4py.PETSc.c: In function ‘initPETSc’:
>>>>> src/petsc4py.PETSc.c:131697: error: ‘KSP_NORM_NO’ undeclared (first use in
>>>>> this function)
>>>>> error: command 'mpicc' failed with exit status 1
>>>>> make[1]: *** [petsc4py] Error 1
>>>> Srinath Vadlamani, PhD.
>>>> Tech-X Corp. Research Scientist
>>>> 5621 Arapahoe Ave. Suite A
>>>> Boulder, CO 80303
>>>> 303-996-2034
