[petsc-dev] error with build
Jed Brown jed at 59A2.org
Mon Nov 15 15:44:41 CST 2010
On Mon, Nov 15, 2010 at 22:21, Barry Smith <bsmith at mcs.anl.gov> wrote:
> It will run cython the FIRST time after a clone but not after a hg pull.
> Which is wrong.  I would like to see this code check if it is a .hg
> repository (for example) and always run cython in that case.
Is it somehow not possible to write correct Make dependencies for cython?
Jed
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101115/48dfc78a/attachment.html>
