[petsc-dev] Problem with latest "petsc-dev" change
Wed Nov 3 18:42:58 CDT 2010
On Wed, 3 Nov 2010, Carl Ponder wrote:
> *On 11/03/2010 06:31 PM, Satish Balay wrote:*
> >     Perhaps we are misinterpriting the errors from the snippets sent
> >     earlier. Please send the complete logs [configure.log and
> >     make.log] to petsc-maint so that we can diagnose the issue properly.
> Satish -- I'll do that -- but could you confirm that I'm really running the
> right sequence of commands? That's usually the problem when I have
> configuration issues.
>    hg clone http://petsc.cs.iit.edu/petsc/petsc-dev
>    cd petsc-dev/config
>    hg clone http://petsc.cs.iit.edu/petsc/BuildSystem
>    cd ..
>    export PETSC_ARCH=arch-linux-gnu-c-debug
>    export PETSC_DIR=$PWD
>    ./configure --with-cc=mpicc --with-fc=mpif90
>    --download-f-blas-lapack=1 --download-hdf5=1
>    --prefix=$PETSC_DIR/$PETSC_ARCH
>    ./$PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py
>    make PETSC_DIR=$PWD PETSC_ARCH=arch-linux-gnu-c-debug all
>    make PETSC_DIR=$PWD PETSC_ARCH=arch-linux-gnu-c-debug install
>    cd ..
Yes - the above is the correct sequence.
> I've tried some variations but am not seeing any difference. For
> example, do I need to run bothconfigure andreconfigure?
Nope. only one. For a fresh clone there is no reconfigure script
available anyway.
Satish
