[petsc-dev] Problem with latest "petsc-dev" change
Carl Ponder CPonder at NVidia.Com
Wed Nov 3 18:40:22 CDT 2010
*On 11/03/2010 06:31 PM, Satish Balay wrote:*
>     Perhaps we are misinterpriting the errors from the snippets sent
>     earlier. Please send the complete logs [configure.log and
>     make.log] to petsc-maint so that we can diagnose the issue properly.
Satish -- I'll do that -- but could you confirm that I'm really running
the right sequence of commands? That's usually the problem when I have
configuration issues.
    hg clone http://petsc.cs.iit.edu/petsc/petsc-dev
    cd petsc-dev/config
    hg clone http://petsc.cs.iit.edu/petsc/BuildSystem
    cd ..
    export PETSC_ARCH=arch-linux-gnu-c-debug
    export PETSC_DIR=$PWD
    ./configure --with-cc=mpicc --with-fc=mpif90
    --download-f-blas-lapack=1 --download-hdf5=1
    --prefix=$PETSC_DIR/$PETSC_ARCH
    ./$PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py
    make PETSC_DIR=$PWD PETSC_ARCH=arch-linux-gnu-c-debug all
    make PETSC_DIR=$PWD PETSC_ARCH=arch-linux-gnu-c-debug install
    cd ..
I've tried some variations but am not seeing any difference. For
example, do I need to run bothconfigure andreconfigure?
                  Carl Ponder
This email message is for the sole use of the intended recipient(s) and may contain
confidential information.  Any unauthorized review, use, disclosure or distribution
is prohibited.  If you are not the intended recipient, please contact the sender by
reply email and destroy all copies of the original message.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101103/2f587af0/attachment.html>
