[petsc-dev] Problem with latest "petsc-dev" change
Jed Brown jed at 59A2.org
Wed Nov 3 18:10:53 CDT 2010
On Wed, Nov 3, 2010 at 18:00, Carl Ponder <CPonder at nvidia.com> wrote:
> ./$PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py
In principle, you should always rerun this.  Sometimes you can get away with
not doing it, but it is exactly what is needed to fix your current problem.
Jed
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101103/f4f56153/attachment.html>
