[petsc-dev] Problem with latest "petsc-dev" change
Carl Ponder CPonder at NVidia.Com
Wed Nov 3 18:33:18 CDT 2010
*On Wed, Nov 3, 2010 at 18:00, Carl Ponder <CPonder at nvidia.com
<mailto:CPonder at nvidia.com>> wrote:*
        ./$PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py
*On 11/03/2010 06:10 PM, Jed Brown wrote:*
>     In principle, you should always rerun this.  Sometimes you can get
>     away with not doing it, but it is exactly what is needed to fix
>     your current problem.
Jed -- Running this didn't change anything; thePETSC_FUNCTION_NAME_CXX
is still undefined and I still see the same errors.
Can you tell me if this sequence of commands should work?
    hg clone http://petsc.cs.iit.edu/petsc/petsc-dev
    cd petsc-dev/config
    hg clone http://petsc.cs.iit.edu/petsc/BuildSystem
    cd ..
    export PETSC_ARCH=arch-linux-gnu-c-debug
    export PETSC_DIR=$PWD
    ./configure --with-cc=mpicc --with-fc=mpif90
    --download-f-blas-lapack=1 --download-hdf5=1
    --prefix=$PETSC_DIR/$PETSC_ARCH
    make PETSC_DIR=$PWD PETSC_ARCH=arch-linux-gnu-c-debug all
    make PETSC_DIR=$PWD PETSC_ARCH=arch-linux-gnu-c-debug install
    cd ..
Or are there other commands and/or parameters I need?
                    Carl Ponder
This email message is for the sole use of the intended recipient(s) and may contain
confidential information.  Any unauthorized review, use, disclosure or distribution
is prohibited.  If you are not the intended recipient, please contact the sender by
reply email and destroy all copies of the original message.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101103/0edaeb55/attachment.html>
