[petsc-dev] Problem with latest "petsc-dev" change
Wed Nov 3 18:17:15 CDT 2010
On Wed, Nov 3, 2010 at 6:00 PM, Carl Ponder <CPonder at nvidia.com> wrote:
>  *On 11/03/2010 05:43 PM, Satish Balay wrote:*
>  Perhaps you pulled petsc-dev - but not BuildSystem - so they are out-of-sync?
> Satish -- here are the commands I used:
> hg clone http://petsc.cs.iit.edu/petsc/petsc-dev
> cd petsc-dev/config
> hg clone http://petsc.cs.iit.edu/petsc/BuildSystem
> cd ..
> export PETSC_ARCH=arch-linux-gnu-c-debug
> export PETSC_DIR=$PWD
> ./configure --with-cc=mpicc --with-fc=mpif90 --download-f-blas-lapack=1
> --download-hdf5=1 --prefix=$PETSC_DIR/$PETSC_ARCH
> make PETSC_DIR=$PWD PETSC_ARCH=arch-linux-gnu-c-debug all
> Note that while I pulled BuildSystem, I haven't taken any special steps to
> install it, I just run the installation steps for petsc-dev in the parent
> directory.
> This is what I get from reading
> http://www.mcs.anl.gov/petsc/petsc-as/developers/index.html#Obtaining
> although I'm skipping the steps
> hg pull -u
> ./$PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py
> Are these necessary, given that I've pulled the updated trees and run the
> configure & make?
You are using terms imprecisely. By "pull", we mean
  hg pull -u
not a clone. Pull updates the repository:
  http://mercurial.selenic.com/wiki/Tutorial
  Matt
> Thanks,
>                     Carl Ponder
>  This email message is for the sole use of the intended recipient(s) and
> may contain confidential information.  Any unauthorized review, use,
> disclosure or distribution is prohibited.  If you are not the intended
> recipient, please contact the sender by reply email and destroy all copies
> of the original message.
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101103/8359acf0/attachment.html>
