[petsc-dev] Problem with latest "petsc-dev" change
Wed Nov 3 15:21:05 CDT 2010
On Wed, 3 Nov 2010, Matthew Knepley wrote:
> Since you use our version control system, you will never have to worry
> about something breaking. If something does not work after a pull, just
>   a) rollback to the previous revision, 'hg update -r <rev>'
Or if you don't remember the previous 'working' revision - before
pulling the broken changes, you can revert your pull with:
hg rollback
hg update [or 'hg update -C' - if appropriate]
Satish
>   b) rebuild
> No need to worry.
