[petsc-dev] Problem with latest "petsc-dev" change
Carl Ponder CPonder at NVidia.Com
Wed Nov 3 17:38:55 CDT 2010
Satash -- the filepetsc-dev/include/petscsys.h contains a statement
    25   #if defined(__cplusplus)
    *26   #  define PETSC_FUNCTION_NAME PETSC_FUNCTION_NAME_CXX*
    27   #else
    28   #  define PETSC_FUNCTION_NAME PETSC_FUNCTION_NAME_C
    29   #endif
I don't see thisPETSC_FUNCTION_NAME_CXX declared anywhere in the source
base, and am running into errors of the form
    /home/cponder/CUDA/PFlotran/petsc-dev/include/petscsys.h: In
    function 'PetscErrorCode PetscMemcpy(void*, const void*, size_t)':
    /home/cponder/CUDA/PFlotran/petsc-dev/include/petscsys.h:1828:
    error: 'PETSC_FUNCTION_NAME_CXX' was not declared in this scope
    /home/cponder/CUDA/PFlotran/petsc-dev/include/petscsys.h:1829:
    /home/cponder/CUDA/PFlotran/petsc-dev/include/petscsys.h:1831:
    /home/cponder/CUDA/PFlotran/petsc-dev/include/petscsys.h:1835:
when I build SAMRAI. Can you tell me what is missing?
             Carl Ponder
This email message is for the sole use of the intended recipient(s) and may contain
confidential information.  Any unauthorized review, use, disclosure or distribution
is prohibited.  If you are not the intended recipient, please contact the sender by
reply email and destroy all copies of the original message.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101103/ce693af2/attachment.html>
