[petsc-dev] Problem with latest "petsc-dev" change
Wed Nov 3 15:15:31 CDT 2010
On Wed, Nov 3, 2010 at 3:12 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Wed, 3 Nov 2010, Carl Ponder wrote:
> > *On 11/03/2010 01:33 PM, Satish Balay wrote:*
> > >     for http there is no '$USER:$PASSWORD@' in the URL [I guess its
> just
> > > ignored - so it works..]
> > >     I pushed a fix now.. You can pull and retry [after 'hg revert
> configure'
> > > - to remove your local changes]
> > Satish -- thanks -- it works now.
> > Is thepetsc-dev stable enough to update on-the-fly like this,
> Well - petsc-dev is always in flux. If things are broken - and we see
> it [or someone points it out] - we try to fix it up as soon as
> feasiable..
Since you use our version control system, you will never have to worry
about something breaking. If something does not work after a pull, just
  a) rollback to the previous revision, 'hg update -r <rev>'
  b) rebuild
No need to worry.
   Matt
> > or do you have release versions we should we be using?
> There is petsc-3.1 release - but if you need petsc-dev for pflotran -
> then I guess thats what you would have to use
> You can always sync with petsc-dev in lockstep with Bobby - if thats what
> you are doing.
> i.e [each time you resync with Bobby] get the changest number for
> petsc-dev and BuildSystem clones Bobby is using:
> hg tip; hg tip config/BuildSystem
> now use these rev numbers to update your petsc-dev
> hg pull -u -r 'rev-petsc'
> cd config/BuildSystem; hg pull -r 'rev-buildsystem'
> Satish
> >     -- Carl Ponder
> > This email message is for the sole use of the intended recipient(s) and
> may
> > contain
> > confidential information.  Any unauthorized review, use, disclosure or
> > distribution
> > is prohibited.  If you are not the intended recipient, please contact the
> > sender by
> > reply email and destroy all copies of the original message.
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20101103/7667103f/attachment.html>
