[petsc-dev] Petsc-dev compilation: error because of underscore.
Vijay S. Mahadevan vijay.m at gmail.com
Tue Jan 26 19:36:32 CST 2010
Satish, thanks for the patches. I'm applying them now and rerunning
the configure.
Btw, the second patch file link is missing a 'raw', just in case if
someone else is trying the same. I'll let you know soon if the patch
worked.
Vijay
On Tue, Jan 26, 2010 at 7:22 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Tue, 26 Jan 2010, Vijay S. Mahadevan wrote:
>> I do not have mercurial installed on my cluster and do not have the
>> priveleges to do so now. I used the tarball for petsc-dev from the
>> link in the site. Just do let me know if the tarball will contain this
>> update. Or if it is not too much trouble, I would appreciate it if you
>> can send me a patch.
>> Either way, do let me know which option will work for my situation. Thanks.
> the fixes are pushed now
> As Barry mentioned - if you'd like to use mercurial - you can install
> it in your filespace.
> And if you are using 'nightly distribution tarball' - it gets updated
> every night. [so you'll have to wait for that].
> And if you are obtaining 'repository tarballs from mercurial server' -
> they will have all the current changes [the tarballs are autogenerated
> from the repository - when the url is accessed]
> http://www.mcs.anl.gov/petsc/petsc-as/developers/index.html
> And if you want to just get the patches - apply the following 2 patches [in order]
> http://petsc.cs.iit.edu/petsc/petsc-dev/raw-rev/cd154f2fd487
> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/c2d0fd8c54f7
> Satish
