[petsc-dev] Petsc-dev compilation: error because of underscore.
Vijay S. Mahadevan vijay.m at gmail.com
Tue Jan 26 20:59:31 CST 2010
Thanks for all the quick fixes guys! My build went through smoothly
without any other issues. And I'm able to run the example programs
also.
Vijay
On Tue, Jan 26, 2010 at 7:36 PM, Vijay S. Mahadevan <vijay.m at gmail.com> wrote:
> Satish, thanks for the patches. I'm applying them now and rerunning
> the configure.
> Btw, the second patch file link is missing a 'raw', just in case if
> someone else is trying the same. I'll let you know soon if the patch
> worked.
> Vijay
> On Tue, Jan 26, 2010 at 7:22 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> On Tue, 26 Jan 2010, Vijay S. Mahadevan wrote:
>>> I do not have mercurial installed on my cluster and do not have the
>>> priveleges to do so now. I used the tarball for petsc-dev from the
>>> link in the site. Just do let me know if the tarball will contain this
>>> update. Or if it is not too much trouble, I would appreciate it if you
>>> can send me a patch.
>>> Either way, do let me know which option will work for my situation. Thanks.
>> the fixes are pushed now
>> As Barry mentioned - if you'd like to use mercurial - you can install
>> it in your filespace.
>> And if you are using 'nightly distribution tarball' - it gets updated
>> every night. [so you'll have to wait for that].
>> And if you are obtaining 'repository tarballs from mercurial server' -
>> they will have all the current changes [the tarballs are autogenerated
>> from the repository - when the url is accessed]
>> http://www.mcs.anl.gov/petsc/petsc-as/developers/index.html
>> And if you want to just get the patches - apply the following 2 patches [in order]
>> http://petsc.cs.iit.edu/petsc/petsc-dev/raw-rev/cd154f2fd487
>> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/c2d0fd8c54f7
>> Satish
