[petsc-dev] Petsc-dev compilation: error because of underscore.
Tue Jan 26 18:28:44 CST 2010
On Tue, 26 Jan 2010, Barry Smith wrote:
> On Jan 26, 2010, at 6:04 PM, Matthew Knepley wrote:
> > Pull PETSc and try again.
>  NO! Pull BuildSystem and try again. Send configure.log and reconfigure.py if
> it fails.
The bug exists as of petsc-dev from today.
ValueError: The option --known-sizeof-void_p should probably be --known-sizeof-void-p
>  Matt, revert any silly changes you just made to petsc-dev to fix this
> nonexistent problem.
This fix brings up other things.
ValueError: The option --known-sizeof-long_long should probably be --known-sizeof-long-long
All can run with '--with-batch=1' on their machines to reproduce the problem. [and see if their fixes fix it or not]
Satish
