[petsc-dev] Petsc-dev compilation: error because of underscore.
Tue Jan 26 18:15:43 CST 2010
On Tue, Jan 26, 2010 at 6:11 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Jan 26, 2010, at 6:04 PM, Matthew Knepley wrote:
>  Pull PETSc and try again.
>  NO! Pull BuildSystem and try again. Send configure.log and reconfigure.py
> if it fails
1) No this is wrong
>  Matt, revert any silly changes you just made to petsc-dev to fix this
> nonexistent problem.
2) I made the correct change. Look at it first, and then tell me its wrong
  Matt
>   Barry
>>  Matt
>> On Tue, Jan 26, 2010 at 5:47 PM, Vijay S. Mahadevan <vijay.m at gmail.com>
>> wrote:
>> Hi,
>> I'm  trying to install the development copy of Petsc in a linux
>> cluster. The configuration proceeded fine until I had to run conftest
>> for the batch system. After running conftest in a node and then
>> running reconfigure on the main node, I get the following error.
>> Traceback (most recent call last):
>>  File "./reconfigure.py", line 25, in ?
>>  configure.petsc_configure(configure_options)
>>  File "/emchome/vijaysm/soft/petsc-3.0-dev/config/configure.py", line
>> 150, in petsc_configure
>>  check_for_option_mistakes(sys.argv)
>> 33, in check_for_option_mistakes
>>  raise ValueError('The option '+name+' should probably be
>> '+name.replace('_', '-'));
>> ValueError: The option --known-sizeof-void_p should probably be
>> --known-sizeof-void-p
>> I could not find the location where "--known-sizeof-" is read from or
>> else I could've tried to change this and reconfigure petsc. Do let me
>> know if there is a fix for this.
>> Thanks.
>> Vijay
>> experiments lead.
>> -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100126/9599f1bf/attachment.html>
