[petsc-dev] Petsc-dev compilation: error because of underscore.
Tue Jan 26 18:30:30 CST 2010
On Tue, Jan 26, 2010 at 6:28 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Tue, 26 Jan 2010, Barry Smith wrote:
> > On Jan 26, 2010, at 6:04 PM, Matthew Knepley wrote:
> > > Pull PETSc and try again.
> >  NO! Pull BuildSystem and try again. Send configure.log and
> reconfigure.py if
> > it fails.
> The bug exists as of petsc-dev from today.
> ValueError: The option --known-sizeof-void_p should probably be
> --known-sizeof-void-p
> >  Matt, revert any silly changes you just made to petsc-dev to fix this
> > nonexistent problem.
> This fix brings up other things.
> ValueError: The option --known-sizeof-long_long should probably be
> --known-sizeof-long-long
Ah, will you make a list or should i?
  Matt
> All can run with '--with-batch=1' on their machines to reproduce the
> problem. [and see if their fixes fix it or not]
> Satish
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20100126/bad06cb6/attachment.html>
