[petsc-dev] Old docs for petsc-dev
Fri Jan 8 12:35:35 CST 2010
On Fri, 8 Jan 2010, Jed Brown wrote:
> On Fri, 08 Jan 2010 19:04:49 +0100, Jed Brown <jed at 59a2.org> wrote:
> > On Fri, 8 Jan 2010 11:52:15 -0600, Matthew Knepley <knepley at gmail.com> wrote:
> > > That is small potatoes. QCT shows each diff for each changed files,
> > > all unknown files, lets you choose which to commit, and also lets you
> > > select changes to commit.  It is fantastic. Everyone needs to get it.
> > Sounds exactly like git citool.
> I just tried QCT, and it's similar to git citool, but with a very clunky
> interface for selecting hunks, and as far as I can tell, no way to break
> hunks (select individual lines).  TortoiseHG has "hgtk commit" which has
> a nicer interface, but still doesn't let you break hunks.  Apparently
> the hg crecord extension (curses) can break hunks, but it's not
> distribute with mercurial.
I guess the interface is different than citool - hence not intutive..
You can right-click on the filename to get an additional menu - which
has the 'select changes to commit' option.
qct also works with git, svn etc..
Satish
