[petsc-dev] Old docs for petsc-dev
Jed Brown jed at 59a2.org
Fri Jan 8 12:21:46 CST 2010
On Fri, 08 Jan 2010 19:04:49 +0100, Jed Brown <jed at 59a2.org> wrote:
> On Fri, 8 Jan 2010 11:52:15 -0600, Matthew Knepley <knepley at gmail.com> wrote:
> > That is small potatoes. QCT shows each diff for each changed files,
> > all unknown files, lets you choose which to commit, and also lets you
> > select changes to commit.  It is fantastic. Everyone needs to get it.
> Sounds exactly like git citool.
I just tried QCT, and it's similar to git citool, but with a very clunky
interface for selecting hunks, and as far as I can tell, no way to break
hunks (select individual lines).  TortoiseHG has "hgtk commit" which has
a nicer interface, but still doesn't let you break hunks.  Apparently
the hg crecord extension (curses) can break hunks, but it's not
distribute with mercurial.
Jed
